1 - 9 of 9 Posts
I have a 1800c. When I ride the oil appears to be leaking out of a small hole on the front left side and rear right side of motor. Is not a continuous leak. You could say it pukes it out. I attached a photo. Just trying to make sure its not something internal going wrong cause I have clean the oil up and continue riding. Honda tech believes it could be a gasket and they're not sure what the hole's is are for, or they just don't want to tell because they could make $850 to pull motor and replace gaskets. Thanks
Here are some more photos. The oil is also leaking on the back side of the motor. Just under the exhaust port there is also a small hole that oil is leaking from. The oil isn't leaking from the spark plugs. Its coming from a small hole(the first pic shows the hole).I trying to figure what the holes is and its importantce.
Could it be the hand on the mouse? JK
I must masturbate too much, cause I'm either going blind or your pix
is fuzzy.:dontknow:
We probably need a better pix and more detail. Where exactly is it leaking from?
I'm attaching the link for the repair manual to help you narrow things down.
Service Manual
http://downloads.hondatech.info/Mot...X1800 C 02-03 Service Manual ENG By Mosue.pdf
Parts Manual
http://downloads.hondatech.info/Moto/VTX/VTX1800/VTX1800C Parts CAT..pdf
OOPs, sorry - quoted the wrong post. Still concerned about the mouse.
2nd pic looks like oil running down from under the valve cover. Is that stuff on the valve cover green? Other pics could be too, or someone took off the heads and boogared the mating surface creating an oil leak. Trace the oil and confirm the source of the leaks.
Could also be from teh spark plugs, take off the spark plug covers and see if that is where it is starting.
1 - 9 of 9 Posts
