Has anyone heard of a Headlight Oscillator ? If so, where can I get one ?
yes ... the one i have comes with a relay and bypasses
the headlight wiring and goes directly to the battery ...
will have to see if i can find the name of the company ...
I think its called a headlight modulator.
It is called a headlight modulator. Kisan makes one. Signal Dynamics makes another. HDL sells both.
Hope it helps you.
John
They are one of the easiest installs you will do. Mine works when I have the high beam switch on and is off with low beam and when it gets dark. People really do see and react to it. I've had several people pull to the side thinking I was an emergency vehicle.
