1 - 20 of 27 Posts
yes take the hubbys glasses off and put yours on :lol:
its in the video card im sure but you may try de glossing the monitor just for the sake of trying..
other than that ,,has to be the card
some main boards have on board video,,,,some have a card that fits in the motherboard slot,,,cant really say what one you have tho
cant really be the monitor if part is clear[text] and part is blurry
· Senior Moments
Guess I will have to take the PC tower apart and tinker with the insides a bit. Hope I don't get zapped :p
may not hurt to try if your like me ,,,where mine runs 24/7..
try a cold boot up..
turn computer off for 30 seconds then restart..
if you remove your side cover,,,the cord that comes from the monitor and hooks to the puter...
if it hooks directly to the motherboard,,,then a new card can be used instead,,,if it hooks to a card on the board you can get another card..
but it has to be the card...
now i do know when i use my v as a monitor the pics are fine but the text flashes really fast,,,makes it a pain to look at,,,and that from my video card...
try the de glossing and even your monitor settings,,,you may be able to fine tune it some and live with it or least make it better
· Senior Moments
Discussion Starter · #12 ·
Ricstir said:
no reason for you to take off the cover to just LOOK at the card....you degauss the monitor, not the card..it is a function of your monitor, not you card...
plug in another monitor and see if it is the monitor or the computer...then you will know which way to go
Where do I go to look at the monitor card? Control Panel?
Not a card. Menu button on the monitor.
if after trying the adjustments on the monitor and that doesnt help ,,another monitor isnt gonna help either,,,either the pixels are good or their bad in a monitor..
contrast and sharpness will make a image look blurry but usually it will make text look that way too
CC if i had the problem heres the steps i would take to diagnose
id do the monitor adjustments
id check and make sure the monitor cord is secure--remove then connect
If i had a video card and also my motherboard had on board video---i would move the monitor cord to on board and check
if no on board i would remove the cover and remove the video card and reseat it
if i had a empty slot i would put it on that one[sometimes motherboard slots go bad]
if all of this failed i would install another video card ...
if you like i can probably send you a video card to see,,,i give all my old puter stuff to my son and i do recall recently seeing him still have my old raedon video tv card in his stuff
well the first step should have been to take off the old mans glasses :lol:
· Senior Moments
Discussion Starter · #16 ·
This is going to drive me nutty....Now, some pictures come in clear and some are still fuzzy. I tried my old monotoe, and the same thing. Oh well, Guess I can live with some fuzzy pics!
you sure you didnt lower the resolution on some of your pics,,,or perhaps used a program that did it?
try going on the internet and viewing color images and see how they look to you cc
· Senior Moments
Discussion Starter · #18 ·
Didn't change a thing! Color images seem to be fine, except on VTXOA. In fact your avatar and sig pic are blurry to me.
if ya had mentioned that little tidbit of info ,,,coulda saved ya a few grey haris there :lol:
so your graphics is ok everywhere except on vtxoa?
assuming your using the same browser to go elsewhere on the net and vtxoa is only one that shows blurry images...im lost ...
i would say your using low quality images in here but even that dont explain why my image is also blurry[assuming it blurrier than before]
you can try going in the settings of the browser itself and mess around and test things out,,,,
· Senior Moments
Discussion Starter · #20 ·
LOL, gray hair, me???? :wink: (not as long as I can dye it)!!
Just got back from a little ride, hoped that the problem would have magicaly gone away! Still fuzzy...
1 - 20 of 27 Posts
