I don't have any yet, but suppose I plug the pair inlet, just to test it out, and the "gurgling" develops after a little while, and I like the sound....would it be mechanically sound to leave it as is, or will i be doing damage, other than the sound?
The reed valves may start to rust. I guess if that happen there is a possibility that you would get water in your exhaust port. Spike may be able to elaborate. I would just do the desmog. It's not that hard.
Mad Hatter
You can just plug them.. Just make sure U still take apart the valve and just use the stock cover with a rubber plug.
There is 2 gurgles heard on this bike. 1 can be from the coolant system. Take the rad cap off and clean it with a toothbrush under the rubber gasket.
2. A plugged pair system hose that has had condensation build up inside. This has lead to water being sucked into the exhaust port making a great steam show. That isn't the trouble as I see it, the steam means it burned the water off anything it touched. Where I see the trouble is if that water was to drip down into a cold engine and water likes to corrode stuff, so rust inside the engine would be my worry.
so basically....don't risk it?
Im plugging it today just for the testing purposes, and if I like it I'll go through with the rest during the course of winter.
No, for testing or even a few months of riding with it plugged is OK. Just not a good idea for long term
