1 - 15 of 15 Posts
I checked Dynojet.com and bareasschoppers.com or a fitting map but I can't really find one fitting to my bike.
VTX1800C '03
modified airfilter housing
K&N filter
Desmog
Cobra speedster shorts
Does anyone has anything close?
Hans
Verstuurd vanaf mijn SM-G920F met Tapatalk
Send me a pm as i think i saved one on my laptop that should work.
Just need your email and a day or 2 to dig it up.
Just sent from the laptop so you should have it in an attachment.
Discussion Starter #7
Thanks charlie. I look in to it. PC is new to me. So I have to figure out what to do.
You can also contact Dynojet Research in Oss. They make the reference maps for European bikes which you can find on the Powercommander website. This way my bike was tuned for free some years ago(configuration VTX1800/Hypercharger/Sideburner)
Discussion Starter #9
Thanks. But my bike is not a european one. Its an imported one from the states, as most VTX here are. It has miles on the speedo instead of km/h.
OK, if you need any help with installing the map send me a PM.
Pieter
Let me know how the bike responds then if needed we can do some small adjustments.
That map was made at sea level with temps around 65f
Base setting was 14.1 ratio then i added 2% more in the low rpm area for better take off.
15-20 % throttle is a normal cruise area.
Discussion Starter #14
Hi Charlie
Map didn't install. It's map version 119. That's for the older PCIII. This PCIII (122-411) handles only mapversion 161.
Hans
Hi Charlie
Hans
Ok open map i sent highlight the field and copy then open blank map and paste.
Or you can put in the numbers manual.
1 - 15 of 15 Posts
