Hi everyone. Im new here and blown away by the great advice I am seeing! I just have a quick one for you though:
What are the best intake, exhaust, and PCM options for performance on an 06 1800F?
I have read a lot about how the VTX needs a 2 into one exhaust, yet a lot of people have the vance and hines big shots which are not. And for the intake, hyper charger just hype or is it a performance adding mod? Thanks in advance!
Thunder Hurricane won an intake shootout a while back, true 2 into 1 exhaust system is tops, and the PCIII with a custom dyno tuned map is probably the best you can do in that dept. Kury HC, more hype than hp.
air&pipes
The Vance&Hines big shots have held up well against 2 in 1 with the "cross over Chamber". Put a set of big city thunder baffles about 7 inches of the ends and the torque increases a little by dyno. I have the hyper charger and it hasnt ran out of air on the dyno.
Airboxes;
1. Thunder Hurricane
2. Thunder Teardrop, Tornado, Barons Big Air Kit, Forcewinder, any other open airbox
3. Hyperchargers
Exhaust;
2into2 with a crossover to act as 2into1
Vance&Hines Big Shots
Jardine Drags
2into1;
Supertrap Megaphone
Muzzy Stainless
Welcome to the board!
This is the NEW VTXOA Garage, a sister site to this message board and contains all your How-to/Tips/Tricks/Why’s and links to other helpful sites for your new VTX. http://www.bareasschoppers.com/ A fellow VTX Riders site that has many write-ups on “How-To” do work on the VTX. Also, for you 1300 guys http://vtx1300tips.com/VTX1300TIPS.htm another fellow VTX Riders site.
