Where can I get a pilot screw wrench, d type. The one I got with my Dynojet kit is missing. Ron Ayres has one for $113.00. Little more than I wanted to spend.
It should be easy to make one; you would just need a piece of tubing (copper?) that is just slightly smaller in diameter than a .22 cal shell casing & just flatten one side to make a D shape, it would be worth a try. If all else fails I'll mail you mine......... :D Rod
PM me your address. I'll send one out. I have 2 and I don't need either one. I have the SCain mix screw. I can get it in the mail tomorrow.
Thanks a lot but I got one. The help and generosity of the people on this board is amazing. Thanks, Randy
and for anyone else, use the .22 shell case flattened on one side, it works fine
