Well, finally got my bags mounted using the Ghost Brackets and love it. Unfortunately, both a mixture of the original mounts and the fact that I can't line up worth a darn, I have multiple holes in the plastic on the back of my bags. In an attempt not to do what I would usually do, Ductape the F#%k out of the holes, I thought you guys might have better, weatherproof ideas.
I was thinking of the same thing. I am planning to get some Easy Brackets for my stock bags, which are currently attached to OEM Honda brackets.
I was planning to use some rubber bumpers from an auto parts store, that you'd use for something like a glove box door. They would seal the holes pretty well, but to be sure, I'm going to put a dab of silicone on them.
here is what I did. I put tape on the outer part of the holes. I then filled them with silicone from the inside. When it dried i took the tape off. I can now wash the bike and i get no water inside the bags. I alos put silicone over the bolts on the inside to keep them fron tearing a hole in my leather jacket or chaps. It also keeps your helpmet from getting scratches on it.
I had a multiple holes in the back wall as well after multiple attempts to substitute for Ghost Brackets (not very successful).After rolling over my X and busting out the old useless Cobra brackets I finally purchased Ghost brackets. I resulted to making polycarbonate backing which I placed on the bag - outside wall -to which I attached Ghost Brackets. I sealed the edges with black sealer.
I thought about which direction to put the bolts but because of the lip on the bike side of the bag, I figured that the threads weren't anywhere near anything to scratch. Is there any other reason that most seem to mount with the threads going into the bike?
Great tips guys, i really appriciate it
Go to a truevalue,home depot or even tractor supply. in there hardware dept they sell plastic plugs in multiple sizes that will do the trick.
If the bag is hard plastic or fiberglass and you want a nearly invisable repair... get a fiberglass repair kit or even bondo if it doesn't get much rain on it. Tape a bondo spreader over the hole (resin will not stick to it) on the outside and fill it with bondo or fiberglass resin from the inside using a putty knife to press it in. After it's set pull the outside cover off and you should have a smooth plug, you may have to sand lightly and then paint it to match the bags.
On the other hand, duct tape and a magic marker will make it look more like a Harley.:lol:
