1 - 2 of 2 Posts
has anyone here polished the calipper bracket themselves? if so can you tell me what you used to start the process? it has a lot rougher surface than the other aluminum pieces on the bike. thanks
jbird
I just did mine. Started with 100 grit, then 150, 220 then on to wet sanding: 320,400,800,1000,1500,2000 then Mothers Mag and Alum. polish.
Check out this thread:
http://www.vtxoa.com/forums/viewtopic.php?t=53983&postdays=0&postorder=asc&start=0
I used a Dremel sander (the flat flexible paper, not the drum) to get the corners of the indentation. Tedious job, but while I had the wheel off, I thought, why not? Go for it. Came out looking a little like beaten silver.
Boz
1 - 2 of 2 Posts
