1 - 3 of 3 Posts
I just had the Honda Dealer install a Power Commander usb111 on my VTX1800-C (2003) . The dealer programmed it for what i have , stock air and Roadhouse Shory . The bike still has all the smog stuff on it and still has a bit of popping on decel . If i hold it in 1st or 2nd it popps as i hold it . Could the map be wrong , i do smell a lot of exhaust when its ideling ,almost a rich smell . Or could this be from all the smog stuff on it.
Any suggestions would help....
Sounds like you need a better map. Go to www.bareasschoppers.com and see what Bare has. If that doesn't work, try going to www.dynojet.com and down load one of their maps per your bikes set up. Or best case idea is to find a Dynojet dyno center near you and have a custom map done.
Good luck,
TASSY5
1 - 3 of 3 Posts
