just bought my vtx last week :) love it, it has an aftermarket exhaust with power commander air to fuel chip. not sure how to tune it but i have a hunch its out due to pinging when i let off the throttle, its not real bad babying it but when you let off the throttle after getting on it , it sounds like your on the beaches of normandy :shock: any ideas on proper tuning techniques? this site rocks
Welcome to the board!
That noise we call the "decell pop". To fix it the right way, first remove the pair valve system. This is letting fresh air into the exhaust ports on decell to help with emmisions control. The fix for that is on the VTXOA Garage I linked in the first post and on Bareass' site, http://www.bareasschoppers.com/
This will keep you from throwing fuel at the noise that will lead to plug fouling and wasting fuel. Then you can tune the PC3 with any number of maps on PowerCommander.com, Bareass' site or others. 8)
Since it is a USB model you have a PCIII. You can check dynojets site for another MAP, check Bare's site for another MAP or take your bike to a tuner and have a custom MAP done. First step would be to check http://www.powercommander.com/. Also read the sticky's at the top of the tech page for good info.
Damn,
Spike beat me to it 8)
thanks for the replys guys
:idea:
