Thanks for the reply Spike. I believe you, I'm just curious, why is unplugging better? You run the PC right? Did you dyno yours?Chicago-Spike said:Yes, the zero map is not adding or subtracting any fuel, but the better way to see is to unplug it 8)
No, your bike will not start with it hooked into the ECU with no power too it. You have to remove it comepletely, all lines unpluggedI'm also looking to experiment a little with power commander vs. no power commander. To disable the PC can I just disconnect the power and leave the unit plugged inline of the stock connector and the ECU or do I need to unplug the PC from the ECU? In other words, if I cut the power to the PC, will the stock connector still "run through" the PC wiring to the ECU?
Thanks in advance for info.
