I'm confused here, probably read too much info on the board.
I have an 2005 1800R Spec 3 like the looks and the power but don't like the ride. Its way too rough for me one up. I had a 1300R before this and one up with the stock shocks on 3 - was fine. I'm about 270 and have a 30" inseem. I've given the shocks on the 1800 a try at 2, 3, 4 one up and 5 on the two up.
Two up at 5 is a nice ride. Single I usually are at 3, although the same bumps on the same roads that I hit on the 1300R lift me out of the seat on the 1800R, & 2 doesn't seem much better.
So I'm considering purchasing the Progressive suspension items to try and better the ride.
The progressive fork springs are simple enough - order, pay etc...
The rear shocks are where I'm coming into my confusion. If I purchase the 12.5" length those are the same length according to Hal's site info. From what I understand I need to go with the HD springs. As I understand it the 440's have more than 5 set positions. One post suggested for two up equaling around 430 lbs. (if I recall) the rider set it on 3.5.
Right now I'm almost flat footed on the 1800R, if I drop down to the 12" shock length - or lower am I screwing myself because I am cutting off an inch or more of travel? Or would I be better set up to be flat footed on the X?
I ride two up 30% of the time, also with a larger passenger (she would kill me if weight was mentioned) usually for longer trips.
It seems that the 418's don't have as much adjustment but aside from that come in the same lengths and spring offerings.
Got that credit card ready to go - but just don't know what way to go...
Any help would be greatly appreciated.
Cheers,
Phil
Cheers,
Phil
