Hidden hitch, inside the fender.
Took the fender off and disconnected the tail light wires.
The previous owner had installed a signal light buzzer, and used these .
Don't use them even if it's convenient.
The wires are frayed, and will cause problems from vibration.
vampire clips should be out-lawed...
if a customer came in with intermittent electrical issues. and I found vampire clips...
I changed from flat rate to hourly..
I installed many aftermarket accessories in cars and motorcycles..
hundreds of vampire clips that were New went into the trash.
I will not use them.. period. solder only.
Discussion Starter #4
Seriously considering a single wheel trailer.
Built, not bought.
This is just to display maneuverability..
Finished my hitch & painted it.
I had enough in the scrap bin to do this.
Bought the receiver tube from a local hitch dealer.
Next, start the trailer.
Will be similar to the trailer illustrated .
Reactions: Zym and Hans&Feet
I've read up to page 17 of the flange drive theory .
The failure rate/ trailer use caught my eye.
How many here pull trailers and have had bearing failure?
Yup, the vampire clip strikes again. Glad you found it before it caused more trouble.
I found 3 on my new bike (new to me old bike). Yes, just a silly dirtbike but if the clip decides to bite and shorts out your lighting system in the evening when you're trying to get home in rough terrain, try pulling out a cellphone and holding it up to illuminate your path on the rocks. LOL
I agree, those clips should be outlawed. Yikes. :)
Discussion Starter #8
Danny Macaskill: Danny Daycare
