1 - 13 of 13 Posts
Greetings,
I have a woodies fairing and am trying to put an amp in it. I have the Alpine amp (KTP445A).
I cannot seem to find a place to put it. If I put it on top of the head unit the fairing wont fit together. Unless I put it all the way at the top. then the waterproof door is down for good.
Does anyone have any suggestions where to hide this amp? I am thinking along the side? The top doesn't seem to work very well. Unless I am dumb - which is not out of the question.
I had one in my fairing you until about 4 months ago. It finally quit I believe due to moisture. I have ridden in a lot of rain over the years so I really can’t complain. The amp will fit on either side placed horizontal above the inside and middle bolts that connects the outer and inner pieces.
Which amp did you have? I want to check sizes to see if mine is somehow bigger.
I had the Alpine KTP445U. Same as the one you have but a universal connection in addition to the Alpine version.
Discussion Starter #5 (Edited)
Ah - got it.
Thanks. :thumbup:
Now that I got that in, I need new speakers I think. The ones that came with the woodie don't seem all that great. The sound seems like its underwater.
I have an alpine head unit too (so I had the factory connectors) so I don't think thats it. Any one have suggestions?
EDIT: It was my phone. Stupid iphone 11 needed some tweaks. Now it sounds AWESOME. Too bad I did this at the end of the year.
Ah - got it.
Thanks. :thumbup:
This is what I would suggest. I have the 521 that were the previous model with similar specs.
https://www.crutchfield.com/p_107DB522/Polk-Audio-DB-522.html
Discussion Starter #7
Did you secure the amp? It seems pretty set when I put it in there. I am not sure short of caulking how I would affix it to the fairing?
Industrial strength Velcro and some clear silicone at the corners to ensure it didn’t vibrate lose. It was right were I installed it until the day it was removed.
Discussion Starter #9
Thanks for the help- I think I have this now. :thumbup:
Not sure if this will help, but this is how my amp is mounted in the Tsukayu batwing:
I have since changed the crappy Tsukayu speakers with Polk Audio mm692 speakers, and WOW, they are awesome.
Discussion Starter #11
The tsukayu and the woodies had different clearances in the body of the fairing.
That wouldn't fit there in a woodies fairing. If prkuehn hadn't figured it out I might not have found that spot.
where did you get the polk speakers? I am kind of interested in upgrading.
I dont know if you are asking me about where I got my polk audio speaker or the other poster. But I got mine on Amazon, even came with a free bluetooth headset:
[ame]https://www.amazon.com/Polk-Audio-MM692-Motorcycle-Headphones/dp/B07BVPPRP8/ref=sr_1_5?keywords=polk+audio+mm692&qid=1573755442&sr=8-5[/ame]
Discussion Starter #13
Thanks. Food for thought for sure.
Of course doing this right before I am done riding for the year is kind of dumb. I would have liked to have test it out a bit prior to putting it up.
1 - 13 of 13 Posts
