My fan is not turning on. What should i check. Thank you
First, just flip it with your finger and see if it gets to spinning.
Check fuse under side panel
Check to make sure the plug-in for the fan is plugged in completely.
There is a way to test the temp sensor in the service manual.. you have to ground the temp sensor and the fan should come on immediately.
-Gonz
Read this please;
http://www.vtxoa.com/forums/showthread.php?t=205902
I will move this when I know what model VTX you have 8)
Welcome to the board!
This is the NEW VTXOA Garage, a sister site to this message board and contains all your How-to/Tips/Tricks/Why’s and links to other helpful sites for your new VTX. http://www.bareasschoppers.com/ A fellow VTX Riders site that has many write-ups on “How-To” do work on the VTX. Also, for you 1300 guys http://vtx1300tips.com/VTX1300TIPS.htm another fellow VTX Riders site.
Fan Problem
Look in your owners manual if necessary to find the correct fuse to replace. The fuse is probably blown. Easy fix and it happened to me as well. Good luck Tom
