I put the Radiantz LED tail light in tonight. It is amazing! It increases brightness about 20 times. Chicago Spike said it was great and as usual he is right. The cagers will see this brake light from about half a mile. It is a bit pricey though.
Etcthorne
It took 2 minutes to install . it is a board with about a hundred LEDS on it that is wired to a plug that fits in the existing tailight socket so it is like changing a light bulb. It fits right in the existing tailight assembly. The web site was WWW.Radiantz.com hit tailights, then Honda,then dual intensity. It is so bright that low flying planes can see it. It does cost about $125. but it could save your life and you've probably spent more on chrome . I know I have.
Three Radiantz 128 LED taillight units
One used as a taillight/brakelight
Two used as custom running marker/turnsignals inside
Harley Laydown taillight lenses.
plus two 45 LED units wired as auxiliary brakelights
installed in stock turnsignals with clear lenses painted red
using Testors #1605 Candy Red Transparent spraypaint.
Lighting appears yellow/white in photos due to sensitivity of
digital camera when photographing light sources.
Lighting appears red to human eyes.
taillights off daytime
taillights on nighttime
