1 - 19 of 19 Posts
I really want to improve the look of the rear of my bike. I have been thinking about going with a vertical side mount plate and some small bullet signals. I have also been thinking about this signal:
http://www.customdynamics.com/honda-vtx ... lights.htm
I am open to other ideas so please attach pictures. It is hard to picture something and know if it will look good. I do think it would be nice to see more of the tire and open it up a little. I just really dislike the plate/signsl holder that comes with the bike.
I put on a cheap sidemount (jettink.com) and cut off the thing under the rear fender, signals included. Just need enough money for new signals, and all kinds of other stuff.
And yes, I am riding with shorts, flip-flops, novelty helmet, one hand, no rear turn signals, etc.
and dont forget "waiving" at a cop
DentalRep said:
kai38 said:
http://www.pbase.com/kai38/image/41371486
I moved my plate to the side and put bullets on the fender after cutting away the bracket.
Kirk
When you put the signals on the fender, what keeps them from turning when bumped? I would be worried about scratching the paint. I like the look off the fender.
I put flat star washers on that hold it pretty tight. It took me a long time to measure and make sure the holes I was about to drill were both in the same place. Getting the nerve up to drill into the fender was the hardest part of the whole job
Discussion Starter · #10 ·
RODS X said:
I did this on the rear of my C;
I used the Kury LED light kit that was made to go on a retro on my C & redrilled a HD LED tag frame........ Rod :D
I was just looking at my fender and I see that the factory bracket is welded. Did you have to cut something off to get the Kury lght kit on?
Custom tail
I like my look....... very clean. License plate is vertically mounted under saddlebag.
The kury lights are mounted where the factory signals were,I cut down the factory plate holder & bolted the lighted HD plate holder high on mount to put it close to the fender.I think it worked out pretty good. I started to put one of the Kury lighted tag & signal kits( http://www.hondadirectlineusa.com/stores/product.asp?pid=4202&str=12&ID=698673740 ) ,but wanted to be different.......... :D Rod
Discussion Starter · #14 ·
Anyone else have any other ideas? I would like to see a couple of other options of what others have done.
I am interested in going with a lighted vertical mount and maybe bullets off the fender. I am slightly concerned that the fender may not look right being how far from the tire it is.
1 - 19 of 19 Posts
