Any Tips, Tricks, Mods or any advice that may help me "safely" put a rear fender that has just been custom painted back on without scratching it up. :cry:
The middle fender boly can go on without the strut trim. The fender slides in really easily without hitting anything if you leave that chrome trim off and get those two middle bolts in irst then put the trim onand worry about mounting the shocks later. I just put my fender on last week using this method and didn't scratch a thing, I did not have help and I did not use tape, I wouldn't recommend the latter
I've found that loosening the top shock bolts enough seems to allow the struts to open up far enough for the fender to slip right in...but as Spike suggested, also use masking tape - preferrably the blue painters tape as it comes off easily with little to no residue...
Shocks off, shock mounting special bolt loosened, and outer grab rails off, tape the support arms. As described before, install middle bolts, then outer grab rails, then the shocks.
+1 :D
Discussion Starter · #8 ·
Thanks for the ideas.
Especially this one. Seems obvious now, but I probably wouldnt have figured it out until it was to late. Thanks.
