Trying to replace rear turn signal on 03' vtx 1300 R. I have the service manual and it says to remove rear fender in order to run new light. I'm sure I could splice and solder but for sake of learning to take my bike apart do I need to put the bike on a stand before unscrewing the rear springs? Will I have an issue getting it back on?
thanks
I'll move this to the "1300 Riders" board so you will get some help. You posted this on the "How To" board where threads showing "How To" do something are. You should ask your questions on the "1300 Riders" board for faster help ;)
Welcome to the board!
This is the NEW VTXOA Garage, a sister site to this message board and contains all your How-to/Tips/Tricks/Why’s and links to other helpful sites for your new VTX. http://tech.bareasschoppers.com/ A fellow VTX Riders site that has many write-ups on “How-To” do work on the VTX. Also, for you 1300 guys http://vtx1300tips.com/VTX1300TIPS.htm another fellow VTX Riders site.
