I stored my 02 VTX Retro in a heated shed. The shed is plenty large enough and nothing else has had a problem, temp was 55 on coldest days. I checked it at least once a month and did not notice any oxidation on rear wheel. I pulled it out and took off the bags and noticed the entire rear wheel oxidized and pitted. Front wheel is fine all chrome is fine. The bike was purchased last April as a leftover. I polished the aluminum wheels with metal cleaner and wax, formulated for aluminum.
Has anyone heard of a problem like this?
I have had other bikes with aluminum wheels and never had an issue.
Pulled cff the bags. What bags? Where they plastic bags? That may be the problem. Think about a greenhouse. A good waxing is all it really needs before you put it up for the winter.
Welcome to the board!
