Just to confirm after my first rear wheel removal / tire change.... Does this spaceout between the final drive housing and hub look correct? Just wanted to make sure I didn't have some kind of issue with the spline not properly seating in the final drive.
(I know, I know, the wheels are in bad shape -- It's a used bike, I've been out of the country half of the year and I just destroyed my powerball cleaning the front wheel!)
On a potentially (?) unrelated note: I noticed after changing to Cobra Swept exhausts and these new Metzeler 880F/888R tires, I get an occasional buzz in the frame during deceleration usually at +/-25mph that lasts under a second but is alarming nonetheless. I found a lot of discussion around a potentially similar issue here - http://www.vtxoa.com/forums/showthread.php?358049-Noise-in-rear-of-bike&highlight=buzz+sounds - but didn't see many convincing suggestions. I've never encountered this issue until making these changes. Any thoughts?
Thanks in advance!
Cant help with the buzz, its been a while since I had one..:mrgreen:..as for the wheel only one way, space is correct...its either on or its not....good luck
If it wasn't lined up correctly, your wheel/brake and axle would not fit inside the swingarm. If your wheel is on the swingarm now and it rotates, it's right
Discussion Starter #4
Was just up in your neck of the woods, could have helped you out with that buzz! :mrgreen:
Thanks for the feedback, gents!
Put on a new set of Metz a short time ago.
I too had a buzz/slight vibration at 20-25 mph.
I got it up to 30mph, cut the motor & pulled in the clutch.
It happened from about 25 down to 20.
After a couple hundred miles, maybe a little less, it was gone.
I figure it was the newness of the tires, wearing away the "sharp" edges of the tread.
I noticed that same thing at times on my Shinkos as the face of the tire has worn down. I have come to the conclusion that it is the side threads buzzing sorta like big 4X4 tires do.
