1 - 3 of 3 Posts
Did the pair valve removal, got in a rush to beat the daylite and skipped Roogies re-install of the holder minus the reed. Question, is that holder the gasket or seal for the plate? Bike runs good without and no apparent problems. Guess I should be pro-active and place the holder back in it huh?
Comments welcome as always.
Yes the holder is the gasket. I left the reed in, and just put a "nipple plug" on the connections, (at both heads & airbox) I removed the hose and Tee fitting from the vaccum line at the pair valve, and used it (since it was longer) and replaced the line coming from the carb, so that I now have one line from carb, to Tee, to petcock, and head. Will it hurt anything to leave the reed in there? Condensation? I don't think I have anything to worry about, but would like to hear from someone w/ experience. Thanks.
1 - 3 of 3 Posts
