My wife bought me a pair of Baron Chrome grips to put on my bike but, I'm having trouble replacing them. The only way to replace them is to open the switchbox and remove throttle cables. Unfortunately its not like the iso grips that you can just remove the rubber part from the stock and slide the new ones on. You have to connect the throttle cables to the replacement grips. Which I don't know how to do. I don't want to end up breaking the cables. Any suggestions would be greatly appreciated.
Thank you
Welcome to the board!
This is the NEW VTXOA Garage, a sister site to this message board and contains all your How-to/Tips/Tricks/Why’s and links to other helpful sites for your new VTX. http://www.bareasschoppers.com/ A fellow VTX Riders site that has many write-ups on “How-To” do work on the VTX. Also, for you 1300 guys http://vtx1300tips.com/VTX1300TIPS.htm another fellow VTX Riders site.
Now, as to your question, an easy way to remove the cables is by getting some slack in them by loosening the handlebars in the risers and moving the bars to the left. Now you have the room to slide the grip and all off the bars then remove the cable ends from the throttle sleeve and put the cable ends into the new grip and back onto the bars.
I have a 2003 1300s. Thank you for information, links etc. I really appreciate it. I'll try what you suggested.:grin:
Are the Baron grips something like the Harley grips I keep hearing about having to mod the switch housing to make it fit correctly?
http://www.xtremerevolution.com/sto...oductid=98&CategoryID=21&SectionID=0&gvid=229
I am still stuck on these spike tip grips I saw on Ebay...
http://cgi.ebay.com/ebaymotors/ws/e...20346310861&sspagename=STRK:MEWAX:IT&viewitem=
Especially, if I can the matching pegs, shifter & brake pedal.
Just wondering, if I would have to mod the switch housing for the spike grips as previously mentioned.
Spring is in the air...WooHoo!!!
OhioBob
Discussion Starter · #8 ·
Got her done! Looks great. Thanks for the help guys.
I didn't have to do any modification to the switch house.
