ok here is some history first...
I have an aftermarket airfilter (ultra flow from xtremerevolutions) and a set of custom pipes from Mortons
I did the carb mod with the shims and trimming of the needle holder..
4 shims
and 2 3/4 turns on the a/f screw
removed pair valves
she was running fine but, I was still still getting a loud popping on dec. so I read a few post here and it said to check and make sure the pipe were tight .. so I checked and behold they weren't as tight as I thought.. so I tightened them up and started the bike. it idles really rough then shut off. pulled the choke and same thing but was getting black smoke out of the pipes..
any clue of what it can be? any help would be appreciated..
4 shims
removed pair valves
