1 - 2 of 2 Posts
here's the deal......
just installed the RTB controller from kury and when I turn on either signal, doesn't matter which one, they both go (only on the rear, front works fine). and then when I hit the brake it goes into the flash mode regardless if the flashing tab thingy is installed or not.
someone said I need the diode fix, but I only thought that was if you were running LEDs......I'm running halogens
any ideas?
thanks
loopy
It sounds like a problem with the unit... You should only need the diodes with LED's, but if you think it would help you can try it and see what you're results are.
Do you have LED's anywhere else on the bike?
I would recheck your wiring:
http://tech.vtxoa.com/index.php?action= ... artlang=en
Just to be certain and then maybe call Kuryakyn to see if there is some special "setting" that's not done properly.
1 - 2 of 2 Posts
