If anyone tries to mount saddle bags with cobra brackets,the bolts they send are to short if you have a sissy bar. To make things easyer get some 10mm x 1.25 x 60mm or 70mm.The bolts will have to come from a machine shop or a tractor sales.The 1.25 is the problem most mm bolts are 1.5. The middle bolt is where I had the problem.The rear bolt was not long enough also.I think it was a 8mm not hard to find or match up.
