Administrator
Hi there, I have adjusted the server load limit which should fix this issue for you.
Thank you for bringing it to our attention.
Regards,
CG - Community Support
It's not the server
It has something to do with my account.
It only happens when I am logged in.
I have to try 5 or 6 time to read a post or move to a different thread or forum.
I get the too busy try again message or not found over and over before it takes or my post takes resulting in duplicates often.
So I copy my posts and re paste them until it takes which takes many attempts.
So please check my account to see if its tagged in some way.
I suspect someone hacked the system.
Administrator
I don't think you account is hack.
As for the time you are having problems, do this occur when visiting certain sections of the forum? A certain time?
~ AS, Community Support
Per my post #3 it only happens when I am logged in and it happens no matter what I try to do.Log on,move forums,post,read posts,etc.
If I log out everything works but I can't post or open the hot box so its even difficult to make this post.
Plus I get a lot of duplicates because I can't tell if a post took as I get the busy try again message then I keep trying and end up with duplicates I can't erase.
