Does anyone know right off the top of your head if there is enough linkage adjustment on the Retro to raise the toe end about 1.25"?
Discussion Starter · #2 ·
Anyone?
I don't have a pic to show you but If you remove the left engine cover below the ignition switch you will see the level and splines where to make adjustments, just remove the level and reposition it where you get the adjustment you want.
Thanks,but I am trying to find out how much a guy can bring it up without having to take the side cover off just to experiment.Basically being lazy & thought maybe someone could tell me,if they had done this to theirs?
Carefull not to adj it too far up. If you go too far the linkage will hit in the front end of the linkage and wont shift.
..donut..
