rileysdad said:
You don't have to bleed the brakes after install? I can't see how? Please explain because I'm interested in this product. Thanks
what you do is remove the bolt that holds the existing
reservoir to the frame ... then carefully turn it upside
down so it is below the brake cylinder and then when
you remove the hose from the 90 degree thing there
will be maybe a drop left in the 90 degree to come out:
i just put lots of paper towel around and they absorbed
the drips.
the only time i got any drip was putting the new connector
into the brake cylinder to replace the 90 degree ... hoggone
says push slowly ... i did and then it just popped into place.
if you put some paper towel over the connecter there would
be no splash when you gently push down.
All in all it was an easy job except those two bolts (#31 in the
diagram) that take a 10mm (hoggone calls them 6 mm bolts)
because there is not much room to swing a wrench ... either
use a ratchet style box end or do what i did and take the
two mounting bolts for the whole setup out and undo them
first before you drain anything.
PLEASE NOTE!!!! at no time during this process should you
touch the brake pedal!!!! if you do, and air gets into the
system, then you will have to bleed it.
I was lucky enough to not do that (don't know how i managed
it!) and my rear brake works perfect.
And having that stupid old reservoir and hose gone is a
thing of beauty!!!!
