Hey fellers!
My VTX1800s is having a problem stopping. Rear brakes are basically not exsistent, and the front break locks with the slightest amount of touch. I know I need to replace my brake pads but is that going to be enough? It seems like if I put to much rear brake it will lock the fronts too. I know the brakes are linked in a way that rear brakes also does something like 1/3 of the front brakes. I don't want to spend the money or spend the time if it's not going to fix my issue. ALSO, still getting used to using this site, is this where I post these questions? Is there a sub board I need to go to?
If I just need to replace the pads I need a suggestion as to who makes the best. I would rather quality over cheap. Thanks in advance!
May the force be with you from me and Red 5!!
