I'm sure they have been tried. FWIW, after all the tries with other plugs, it's been proven that the Honda OEM Iridium plugs are as good performance wise and last for 100K.
I've found the VTX1800 runs absolutely best on the stock NGK iriduim spark plugs. They should last you 100,000 miles and offer little, in the way of room for improvement. I have not tried the E3 plugs, but it is a commonly accepted fact that such gimmick spark plugs do little or nothing in the way of improving either mileage or performance. They will not last as long as the OEM iriduim plugs. That is certain. While their warranty is 100,000 miles, it is limited to 5 years. Bet they don't replace a lot of them under warranty.
Thx. I try that plug.
I don't have the specific plug # but I'm sure someone else will be along to give you that info. If it isn't in the service manual.
1800 Two NGK choices...50k miles or 100k miles
I posted this in 2013, links added, Click on specs.
#12 Jul 13, 2013
UPDATE This is not the manufacturer >>>https://www.ngk.com/product.aspx?zpid=9784
NGK 6502 IFR5L-11 Iridium/Platinum Spark Plug >>100,000 mile sparkplug<<
SKU: #IFR5L-11
ITEM : # NGK6502
BRAND : NGK
Center Electrode
UPDATE This is not the manufacturer>>https://www.ngk.com/product.aspx?zpid=9311
NGK 5464 BKR5EIX-11 Single Iridium Spark Plug >>50,000 mile sparkplug<< NO platinum on the ground
SKU: #BKR5EIX-11
ITEM : # NGK5464
BRAND : NGK
Center Electrode
Both gapped at .044" per spec sheet
And one more rib on the insulator of the more expensive plug!
>>>> Bill you did not say what year... 2002 OEM spark plug was Toooo Cold.
>>>>>Use the spark plug for 2003 and UP..
