1 - 3 of 3 Posts
2008 1300T
Okay, so in June I changed my fork oil and ever since I have had a squeak in the front wheel. As I only thought I heard it under braking and I knew the front pads were getting low, I changed the pads with new OEM's. When I did this, I took the front wheel off, greased everything and used synthetic brake grease on everything that moves in the front brakes. I also used brake cleaner on the rotor. Put it all back together, still squeaking! I have been paying closer attention to it, and it's not just under braking, but when doing slow maneuvers I can hear it from time to time.
Any thoughts, things I can check?
1 - 3 of 3 Posts
