· Read Only
blew the stock 20 amp/250 volt fuse that came with the horn and i have gone all over hell and back (radio shack,wallmart,autozone,murrys,k-mart) to find a replacement and no one has this fuse.
everything out there is 32 volts.
i did find a 20a/250v fuse but it is ceranmic and dosent work.
can i move to a more common fuse size? if so what rating can i use?
· Sith Lord
Ok...from all the years in trucking...check a Freightliner dealer, Kentworth, International etc. :wink:
I've got them here in stock. Same setup and everything, different brand but it's the same relay.
Take the old one with you, just in case.
Also try Fleetpride or a Truck Pro type place, any place that sells parts for class 8 trucks.
· Read Only
syhman said:
you do not need a 250v fuse....that is its maximum voltage rating...the bike is 12v so 32v/20 amp fuse is good. plain old ordinary automotive fuse
ill give this a shot.
just out of curiosity, what is the diff between a regular fuse and a ceramic one?
