I'm hoping this is a problem I can fix, but when I push my horn button the horn makes a tick tick tick tick tick noise. Any suggestions?
you havent pissed off the mob have you?
might want to step away from the bike for a few minutes after it starts ticking.....
I have had mine well over a year and no problems.
might want to check all your connections, or it may be the relay went bad.
If it's mounted in such a way that it's in a bind, or twisted, it could do that...
Eddie
I have had mine for so long that PEPSX didn't even make the bracket back then.... :shock:
...and it's still going strong, I'm +1 on the relay...auto parts store vary from $2 - $5...
30 second fix too...just swap the wires...
Make sure you have a good ground. I use a Rivco that stopped working and had similar symptoms. It turns out that the bolt I attached the compressor ground to wasn't getting good contact. I ran a new wire and all was right with the world again.
