Hi all, i am a newbie both to this forum and to the VTX after about 30 years from my last cycle experience. I have been lurking awhile and boning up on all the good info here. I have a new '03 C i just got last month and am having a blast. Just picked up a PCIII USB on ebay but have yet to alter anything although i plan to. My question is: A. The zero map would have absolutely no effect on the engine FI would it? ( why do they even have one? ) B. I haven't found a map for a stock C that would perhaps optimize the engine using the pwrcommander. I would like to try it out before adding anything else. Even better would be a stock map with the desmog done as i plan on doing that. Thanks and look forward to all the good info..
Welcome to the board!
Right, it does not add or subtract fuel from the curve, used for troubleshooting EFI problems.
On the Powercommander.com website it has a map for a stock bike. Map#M109-001 The desmog/pair removal will have no effect on the map. That system is after the combustion chamber in the exhaust ports. You can find that map here;
http://www.powercommander.com/109_49statemaps.shtml 8)
THanks CHicago, i guess i overlooked that one..
Here's another question.. It seems the general consensus re: exhaust pipes is that the V&H are the way to go.. from what i have read even with the quiet baffles they are generally considered LOUD.. i would like to improve from the stock pipes but don't really want anything too loud. Any recommendations??
