I have a 2002 Honda shadow 750 with a bent front rim ,will a 2003 Honda VTX 1300 front wheel fit.
You probably should have started a new thread. This is an 1800 board, so questions about 750s and 1300s are a bit removed from the expertise in this group.
But the answer is ‘No’. I’m pretty sure a VTX 1300 wheel will not just bolt up to a Shadow. But, if you are talking spoked wheels, and just want to lace a new rim on to a Shadow hub, I think that would work.
750 has a 6204 bearing, VTX has a 6304 bearing.
VT 750 6204-2RS Ball Bearings (20x47x14mm)
VTX1300 6304-2RS Double Rubber Seal Bearings 20x52x15mm
Axle is different from the 1300.
They have the wheels 1998-2002
#11 RIM, FR. WHEEL 44701-MBA-003 $99
Honda VT750 has many versions.
How are the hub and spokes?
Distance between forks and spacers??
Brake diameter, brake disc alignment to caliper?
1999 to 2007 no brake disc match VTX.
