1 - 16 of 16 Posts
I did search for this and found lots of threads but it seems to me I saw someone that knew where to get a complete replacement switch for like the Honda line lightbar. If anyone knows where I could find this I would be grateful.
Yeah, I saw that one, but if I could get one like comes with the Honda line Lightbar it mounts on the handle bars.
I just drilled my speedo housing and relocated the switch opposite the trip button. Much cleaner, imho. If you want my old mounting bracket, just let me know.
Mike
ps....now that i posted this, i am not 100% that i saved it...but i think i did.
Cool that's the same switch that comes with the Honda lightbar, just get the bracket from MikeWerk and you be all set. I believe the only other place you can get the switch/bracket combo is from the stealer.
Discussion Starter #8
Balrog said:
Hey buddy,
Are you talking about this thread?
http://www.vtxoa.com/forums/viewtopic.p ... =trailtech
Thanks Jeff, found that one already, I thought I saw one that had the mounting bracket and the switch, but I guess I was wrong, gee imagine that, I know you're shocked :shock:
Discussion Starter #9
Mike
Hey Mike, if you find that bracket let me know, and what you want for it.
Thanks,
Bruce
Discussion Starter #13
TRHOD said:
Bruce,
I bought this switch when I got my lightbar, but didn't use it for the lightbar.
http://shop.nationalcycle.com/perl/cycl ... l=hd%2d100
This is the National cycle link I got the above picture from.
http://shop.nationalcycle.com/perl/cycl ... del=hd-100
I used it for the indirect lighting I did. Pretty nice looking switch, chrome.
I'm sure you could use it with any light bar.
Hope this helps, bro.
Thanks Ted, I think I have a work around on this but if it doesn't work out this will be the one I'll grab. Nice to see you post
Call me an electrical idiot, but will this switch also work for the Kuryakyn Light bar?
Discussion Starter #15
As long as the wire gauge will handle it (which thats what these were made for) then you're ok. At least thats my take, I'm no pro ether though.
Thats what I used mine for (before I hummed the bar against a wall)
Trick is to wire it properly with a relay so the load is not flowing through the switch.
1 - 16 of 16 Posts
