What is required to install a tach on this bike? Specifically, is there a way to hook up the signal wire from an automotive tach so the tach will read propoerly? I see vendors sell kits, but I do not believe the tachs are special. Thanks for the help.
If you haven't done a search on this topic, you will want to.
there have been a lot of discussions about needle bounce even among tachs presumably designed for this application. if you want to adapt an automotive tach it may turn out that these will be prone to the same problem so I recommend doing a thorough read so you can do this fully informed
Welcome to the board!
