Removing fuel tank tomorrow to service cooling system and do the ground fix. Any other suggestions for mods, repairs, upgrades, or preventative maintenance while in there? Don't enjoy removing tank, so I wanna do it all while it's off. Thanks (2006 1800S)
Clean / polish tops of the cylinder heads that are a pain to reach. Desmog, valve check/adjustment
You can do the ground fix at the front coil without removing the tank, just slide it backwards. You can also change the cooling fluid without removing the tank, just lift the back.
Bareass Choppers Motorcycle Tech Pages
