Since a few days proud owner of a 2005 VTX 1800. you the fun was only short. The engine stopped after 10-15 min. After a while I could drive a few meters again. The longer I wait, the further I got. Symptoms as if the engine does not get fuel.
I dismantled the tank and cleaned it. After that I noticed that a vacuum was building up. Next to the two fuel lines is still the drain from the hole under the amateur cover. Furthermore, a thin pipe, apparently without a hose. This seems to be the ventilation. However, this is completely tight. With a wire I got in a few cm deep but it is still absolutely tight. No air comes through. Does anyone have any advice?
Thank you, Brian
Thank you, Brian
