1 - 3 of 3 Posts
I just took a quick 30+ mile round trip for lunch, ha!, and kept hearing a strange "loose" sound. Something that just had to be vibrating, coming from the rear. I have been hearing it for a little while now, but it started to worry me this time going interstate speeds. Well I got back to work and remember reading a couple times on here about that helmet lock causing noise. I checked it and sure enough, loose. Thanks again folks for helping us newbies out, and letting us know the common noises / gremlins. It made me feel better instantly!
Ride safe!:thumbup:
With a small set of channel locks just remove it , everyone dose. You will Probally not be able to find a A wrench to fit it because it is so close to the tire and ii will just loosen up again.
Donut
:agree:...remove it to the garbage can or relocate....I used a small allen wrench to loosen mine then finished it off with needle nose....when I went darkside cut the whole mount off, the rare time I lock my helmet , I use a Ruger gun lock.....good luck
1 - 3 of 3 Posts
