1 - 20 of 23 Posts
hello all
so I have an 05 1300 and the clymer manual just says SAE 10w30 does it matter if I get a typical oil or does it need to be motorcycle specific I have searched YouTube and google and most say it doesn't really matter only difference is price in my area choices on motorcycle oil are very slim and very expensive I'm getting ready to put my girl up for the winter and wanted to do an oil change first.
Sent from my SM-N960U using Tapatalk
Any automotive oil that has the "Energy Conserving" seal on it will likely make you clutch slip and wear. Any oil that is JASO-MA rated will be fine for your wet clutch. Many here use Shell Rotella diesel oil as it is JASO-MA rated and is good oil at a good price. Some run automotive 10W40 as it generally is not Energy Conserving. Most 10W30 automotive oils, though, will be Energy Conserving, so really, unsuitable for use in a wet clutch application.
As far as I know, these bikes are better off with 10W40 anyway.
thank you that helps alot I have seen that shell diesel around but never thought I could put it in my bike
thanks again
THIS! ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Nothing more to see or discuss...
sorry not totally dead yet
should I go with the 10w30 or the 15w40 on the rotella?
I can only find rotella 10w40 at home depot but its in available and it says energy saving right on the bottle so dont want that right?
Discussion Starter #7
unavailable at home depot but says I can order it
Clean your glasses.
Check your eyes.
I have never seen any 10-40 labeled as "Energy saving", never a Rotella as 10-40
1900 Home Depot stores, 2900 Wally World with auto center stores and numerous auto parts places and numerous truck stops.
Now would be a good time to use a synthetic with the colder weather.
Rotella T6, flows better in the engine oil galley when cold compared to 15-40.
I have used a lot of 15-40, Chevron, Mobil and Shell Diesel engine oil.
Discussion Starter #10
Clean your glasses.
Check your eyes.
no need to be rude I just saw what I saw on line
here is the link
https://www.homedepot.com/p/ROTELLA-128-fl-oz-10W40-Motor-Oil-550019907/204999686
here is the link
Welcome to the VTXOA in winter! :lol:
people can get short in the winter here - don't take it personal. hans is a stand up guy and will give great advice.
FWIW I put the stupid energy conserving stuff in a bike years ago when this nonsense first started. You will know ifyou do it - the clutch slips. bad. I replaced the clutch - but some just drained it and ran different stuff and it cleaned it up.
Oh, and most run the 15W-40 rotella. To be honest there was an old oil write up by tapper years ago that explained the differences. You might see if you can find it. it was most helpful in explaining why 10 (or 15) W 40 was the way to go.
Reactions: namell13
Discussion Starter #13
I think your right about the discontinued I cant find it anywhere else. home depot doesn't show the back of the bottle so cant be 100%sure on that
I also went to the rotella sight and couldn't find it there either
no hard feelings just saw what I saw
Discussion Starter #14
so the final answer to the milion dollar question is rotella 15w40
thank you everyone for your help
Rotella T4 15W40 is good oil. Rotella T6 5W40 is synthetic and will flow a bit better during cold starts. Frankly either is good oil. Some prefer the synthetic, others prefer to save some cash and use the T4. As far as I know, no one has ever had issues with either.
My son has a '94 VFR750 and has been told by several owners to never use synthetic with that engine. The manual makes some reference to that as well. With parts as scarce as they are for that bike, he just uses the T4 15W40 in his bike and it's been great. Always used the same in our dirt bikes, when we had them.
F.A.
i screwed-up and used Rotella T6 5-40 rather than Rotella T6 15-40 last time.
Checked the empty jug in my shed this morning, it said T6 5-40 :nerd:
No screw-up. That's what T6 is. It's just a bit thinner when it's cold. Same viscosity when it's warm though. What you did won't hurt a thing, in fact you went full synthetic. If anything, that is better.
You'll find that quite often, full synthetic oil has the numbers further apart as synthetic just flows better when cold. Absolutely nothing to worry, or at all be concerned about. In my snow-blower I use 0W30. I can pull start it at -40. With 10W30 the engine would barely spin. Pull starting was out of the question. It's still the same, more or less, when the engine is warmed up.
:thumbup::thumbup::thumbup:
As far as I know, there is no "Energy Conserving" category any more. A trip to Walmart yesterday and I could find no such marking on any brand or weight of oil in the API donut. Many of them have "Resource Conserving" and it looks like that is the new category, and not the same as the former "Energy Conserving". Does that mean that oil bearing the the Resource Conserving mark is also bad for wet clutches ? I can't find anything that recommends one way or another.
1 - 20 of 23 Posts
