1 - 2 of 2 Posts
What are folks using for throttle lube? I used white lithium on my new bars, but my throttle still drags a little. Just curious if there is something better or I just didn't put enough on?
Thanks in advance!
I just use a silicone spray. If you're throttle is dragging it could be because the cables are too tight. If you don't have a tiny little 'jiggle' in the grip then try losening the cables a tad.
1 - 2 of 2 Posts
