1 - 20 of 31 Posts
What is the optimal tire air pressure for my bike. I've heard that "cupping" will occur at the pressure Honda recomends. Should I run higher pressures?
41/41
Dunnies
41/41 is what a do, seems to be doing good for me. No cupping yet 6200 miles.
Later
David
Keep in mind, if you are a big dude or ride double aim for the higher pressure 41/40. If you ride single and are a smaller person 38/36 should be plenty. I have 8500 on mine with lower pressures because I'm not a big person, no cupping.
After 7K I'm just about worn smooth in the center of the rear tire. Front probably has 1K left. They're the Bridgestones & I ride 2 up 1/4-1/3 of the time. I ran 42psi 4 6K then dropped 2 39/39 as it wasn't as harsh. Now 4 fun I'm runin' 30/30.......................
Discussion Starter · #10 ·
Thank y'all for taking the time to answer my question. This is absolutely the best place I've found for VTX info. Thank you all for sharing your experience!
I've got Metzler 880 Marathons and according to Metzler's tire guide it should run 40 in the Front and 42 in the rear. Ride like a rock but the tire wear seems to be what it should be for the 5K I have on them.
Pressure in the S model
Is the pressure the same for the spoke wheels. I thought I had read somewhere it was different.
After 60 mi. of 30/30 w/front feeling like it gained a couple hundred lb. & handling like a slug I up it 2 36/36. Don't have a whole lot left so i'm playin' 'round a bit.
Try uping the pressure to 40/40 or there abouts.
Pressure
After 3,000 miles I took my pressure down to Honda recomendations and very shortly like not even 800 miles I had to replace the fron Dunlop. I now have over 6,000 miles on the Metzler front tire at 38 PSI and it hardly looks worn. I keep 40 in the rear. The front and rear are both Metzler. The only drawback I have noticed in the Metzler compared to the Dunlop is a little more vibration. And the sticking feel around corners is not as good as the Dunlops.
Has anyone running 40/40 checked a tire pressure after a few miles of Summer riding?
It will be in a range of 44-46 PSI, which is kind of riding on bricks.
I keep my at 36/38.(male, 5'10",200lbs, stock [email protected])
I run 40/42. I'm a big dude so the extra psi in the rear. I get 20k plus miles out of both tires but I dont ride too aggressively either. You realize this thread is 15 years old.
After riding, and esp. in heat, the tire psi will go up maybe as much as 5-6 psi. Consider.
Reactions: Tankslapper
1 - 20 of 31 Posts
