Bookmark or save to your favorites folder, these websites, http://tech.vtxoa.com This is the VTXOA Garage, a sister site to this message board and contains all your How-to/Tips/Tricks/Why’s and links to other helpful sites for your new VTX. http://www.bareasschoppers.com/ A fellow VTX Riders site that has many write-ups on “How-To” do work on the VTX. Also, for you 1300 guys http://www.vtx1300tips.com/ another fellow VTX Riders site.
There's a write up on the VTXOA Garage site on sizes and brands used by other VTXOA riders
Thanks, I sasw the list still couldn't fiigure out whcih was more closely matches my metz 200, i like the look of the metz on my bike but its sitting in garage flat and worn out at only 7000 miles on it. Any help is appreciated.
200/60-16
200 x 0.6 = 120 (second number is the sidewall height in realation to the width so the sidewall height is 60% as high as the width)
120 x .03937 = 4.72 (multiplying by .03937 changes the mm into inches)
4.72 + 16 + 4.72 = 25.44 is the combined wheel/tire height in inches
Use the same formula for any tire
205/55-16
205 x 0.55 =112.75
112.75 x .03937 = 4.44
4.44 + 16 + 4.44 = 24.88 combined
200/60-16
Or you can convert the 200 to inches by dividing by 25.4, then multiply the answer by .6 and doubble that answer. then add the rim diameter and you have the same answer. 200/25.4 =7.874. 7.874 x .6 = 4.7244.
4.7244 x 2 = 9.4488. plus 16 =25.4488 Then the most important part. You must add the federal, state and local taxes. apply your senior citizen discount before you figure the taxes, and deduct 3% if you intend to use nitrogen in your tires. Don
thanks
