1 - 20 of 23 Posts
Some of the R & S owners have used Shinko's. IDK what specific sizes or models. Search is a good tool.
Reactions: DrDolittle
If your sticking with the stock size on the front...I would like to see a whitewall in 110/90/19....don’t fergit the pix....good luck
Has anyone put white walls on a stock vtx “c” and if yes what brand and size pls
A VTX with WW's looks real good. I used to see a picture in another members signature of his 1300 S with WW tires and it looked really nice.
My next set of tires will probably be Shinko WW, always wanted to try them. It may be awhile though because my commander ll's only have about 5-6k on them.
I looked at the Shinko’s and they only have the 100/90-19 61H. I’m not sure if the first number would make a lot of difference
Discussion Starter #7
I’m trying my best not to change the rims but I haven’t found an exact match for the 110/90-19 on WW yet if I do I sure will post them on here.
Thank you
It's about 10mm less in width and 18mm less in diameter, so it lowers the front about 9mm in theory. In real life it's a little different, because the loaded radius of the tire at the bottom is different from these numbers.
Discussion Starter #10
Thanks bud I just ordered the Shinko 777 100/90-19 and gonna try it see how it handles.
I just put on a set of the 777s front and rear. The grip is fantastic. I have a ton of confidence going into the corners. I did notice though that they are a very heavy tire, at least on my R where the size is a bit bigger compared to a C .
I have used the Shinko 777's on my 1300 and the 1800. I stuck with the BW because just what Smurfy said. Looks good... hard to keep clean. I'm lazy :)
Reactions: smurfy71
Discussion Starter #14
They look good but hard to keep looking clean
I just put a 777 W/W on with the stock rim and I really like it it grips good and looks awesome haven’t had to clean it yet but it will probably be a bit of a pain lol but it’s worth the looks.
Go to the parts store and get a bottle of spray tire bleach...should do the trick...I just put a shinko SE 890 BW..on the front..really like it...have one for the rear ...for when I pull the CT...
Are you riding on that shinko SE 890 yet? Impressions?
I like them...I’m not aggressive rider....but brakes well and holds in the turns....IMHO good tire for the money....depending on mileage might buy again...:thumbup:
Reactions: icopus
1 - 20 of 23 Posts
