1 - 12 of 12 Posts
When I was looking into a batwing fairing I felt like there wasn't an detailed enough review of the Tsukayu GPS Fairing, and what one should think about when installing. So here is a review, good and the bad.
When I was google searching I saw complaints about the speakers, and that it doesn't have enough power (purchased without the optional amp). So I opted to get the 4 channel amp, they pre-wired it bridged. I will say, this thing is LOUD...
Issues:
1) One speaker is damaged, or defective, it crackles even at low volume
2) Both speaker covers had at one nub broken from over tightening (I only noticed this because of my speaker test I will explain further down)
3) Music doesn't seem to play from my phone via USB (this might be my issue)
4) I get NO signal with the radio antenna
So, it was delivered yesterday pre-assembled without the flat windshield installed. I opened everything and installed indicator lights. I picked the location and went ahead and drilled through the fiberglass. I started with a small drill bit and stepped it up until the indicators just fit (I had to use force to push it into place). I already tapped off of the indicator wires in the headlight bucket. I wanted to keep the batwing removeable, so I put in a waterproof connector between the fairing and the headlight bucket. I also covered the wires with a plastic sleeve.
Indicators (ordered 2 of these):
Here is how it looks inside, wired up with the amp:
Here is the initial fitting on the bike. Sorry I did not include how I setup the brackets:
I ordered the 10" smoked windshield. I am 6'2", sitting on the factory seat I am looking though the windshield. I have a corbin seat, that sits me considerably higher, so this will be perfect with that seat. I will also get a 5" or 8" to use with the factory seat.
While I am testing, I have the tank off, and borrowed a so-so car battery from a local mechanic to use so I don't damage my bikes battery.
Here is a clip of how you can hear the speaker damage. I noticed it right away. I swapped the speakers left to right and the sound carried with the speaker, so it is clearly the speaker and not the wiring. I hope the clip doesn't get taken down from youtube, but here it is:
EDIT: NOT SAFE FOR WORK (LANGUAGE)
I have sent a message to the vendor with my issues, hopefully they will resolve them.
I am happy with the batwing fairing, even if they do not resolve it. Some day in the future I will upgrade the speakers.
Discussion Starter #2
UPDATE: I contacted the US based (Florida) representative. I passed along my issues, he is going to pass this along to the China team and have them replace the speaker, speaker covers, and see if there is a solution to the bad radio reception.
Discussion Starter #4
Hey JPT,
I clicked on the link and it says video not available. Nice writeup with always good to have pics. Hope everything gets resolved in a timely manner.
The 2 videos show as links to you? They show as embedded youtube videos to me. Are you viewing via desktop?
Yeah, I'm viewing on my PC running Win7. I see the embedded Youtube video, only one, under the heading: EDIT: NOT SAFE FOR WORK (LANGUAGE)
When I click on it, it tried to load the video and then says "Video Unavailable". Just confirmed again.
So, an update:
1) I sent an email to Tsukayu and they are sending 1 replacement speaker.
2) Regular radio signal is garbage, I got an aftermarket antenna and it worked only while holding it (I would need a powered antenna I think)
3) I got Polk Audio MM692 (6x9) Marine speakers and installed them
Polk Audio Speakers Installed:
I setup the gain and crossovers for maximum sound without damage. I have to say I am very impressed with my setup. I gave up on radio, but I'm not sure I need it. I have Pandora, SiriusXM Radio, and a 64GB SD card with all my songs. I also have Waze, Google Maps to use when online (tethered to my phone), and have the Tsukayu suggested offline GPS Maps on order (SD card).
I had to get longer bolts and used a stack of washers to lower my light bar about 3/4", just enough for the lights to clear the batwing cover.
So hear it sits all back together and wired up to the battery (I've been using a car battery for setting everything up):
Please excuse the mess on my shelf
I plan to get some black racing stripes down the center of the front/rear fenders and gas tank. I like the contrast of black covers and the black batwing. I think having it all silver would be a bit boring.
My future plans, Black Gel coat Tsukayu Saddle Bags. But I have spent enough this year, and I already have leather (leather like) bags.
Discussion Starter #7 (Edited)
Added wind deflectors that I picked up on facebook... I had to use a combination of 2 Cobra extender brackets to get it to work. I also put on 2 layers of wax on the batwing fairing.
I can’t wait to actually ride it and see how she is. I will likely pick up 2 smaller windshields before spring, a small 4-5 inch one and a 7-8 inch one.
I just assume I will need the wind deflectors, since I haven't been able to ride the bike yet... Winter sigh...
Discussion Starter #9
The weather hit 59° today, so I took the bike off of the Redline stand and did a shake down run. I have to say with my longride shield 8” (measured from bolt hole so about 7” above the fairing) and the ultimate bigboy seats and the lower fairing deflectors the ride is smooth all the way up to 85 mph. Today was an unusually windy day too. I just added the seat, it is REAL nice.
The bad news... About 5 minutes into my ride one side for the bridged amp stopped working. I took it back home, opened the fairing and tested by swapping inputs, outputs, and everything follows 2 of the 4 (it is bridged) channels.
But even at 85, I could hear the music clearly with my half helmet and earplugs with one speaker.
Tsukayu has been very resposive, but as I did with the speakers, I may go with an better 2 channel amp. But either way I will warranty the amp, and install it for now.
Discussion Starter #11
I just picked up my batwing front cover from a wrap shop. They did 2 colors Silver (with heavy flake) and Black, they also put a clear bra over the wrap. I’m loving it!
1 - 12 of 12 Posts
