1 - 14 of 14 Posts
Greetings.
I have taukayu bags. The bags had a wire come loose and I attempted to fix it. There are two little capacitors or something in the bag by the light - it came loose there.
After I pulled it and attempted to fix it, none of the turn signals work at all. I checked the fuses behind the right side cover and they are all good. The horn works, so I don't think thats it. Any ideas? I need to get this fixed in the next day or so as I am headed to sturgis - hate to do that without turn signals.
Edit: This is a 2007 T model spec 1 if it matters.
Remove the heat shrink so we can get a better view.
Is it a load resistor? Possible if leds replaced incandescent lamps.
Here it is without the heat shrink.
Wood Data transfer cable Ac adapter Tool Cable
Yep, load resistors to keep same load as incandescent bulbs for flash frequency.
Thanks. Can I buy a replacement at an auto parts store? It says 20w 12rj on the side.
is that what I need to buy?
Those are 2ea 12ohm 20w resistors in parallel. If you want to duplicate that then that's what you'll need. Those are ceramic resistors. Or, if you get a 40W 6ohm resistor, it will be the same. Ideally you want the bigger package to help distribute the heat. These things get hot if on for a long time. For me the higher the wattage rating the better. If you can find 2ea 40w 12 ohm resistors, that's better.
You can get those from Amazon, or a local electronics supply store. Doubtful a auto supplier would have them.
Discussion Starter · #11 ·
I have tsukayu lights and the Orem up front.
Harmon, do you have a link to what I would want?
Discussion Starter · #12 ·
I did a cheap repair - I clipped the wires and reattached them and wrapped the whole thing in electrical tape. Didn't solder yet as I don't have my iron. It works, but long term I will need a better solution. It should get me through sturgis though.
You can keep the 24 watt heaters aka resistors.
You can increase the resistance a bit more to produce less heat.
2 x 12 ohms, 20 watt resistors per side (6.0 ohms, 2 amps, 24 watts) normal flash rate, hot.
2 x 15 ohms, 20watt resistors per side (7.5 ohms, 1.6 amps, 19.2 watts) slightly faster flash rate, less heat..
2 x 20 ohms , 20 watt resistors per side (10 ohms, 1.2 amps, 14.4 watts ) slightly faster flash, less heat).
SM-3R >> no resistors!
Also has 4-way flasher and a few other choices.
Reactions: DrDolittle
1 - 14 of 14 Posts
