i need help i added turn signal mirrors to my VTX and now i need to add a diode into the turn signal lamp indicator circuit.... Which wires :?: are they on the back side of the dash board panel?????
Head lite bucket and right side cover in the rubber boot there are connections you can use. Headlite bucket is probably the easiest to get to. Just because they flash fast, is not a bad thing. Gets peoples attention.
This may help also
http://bareasschoppers.com/diode/
Thanks,
Smoken , HOT, thanks for your help that was just what I was look'n 4...if your ever in Tucson let me know theres some nice rides ............and beer just taste colder when is HOT out......
Cool, glad I can help
Don't know how you guys ride in that weather. It's 85* and muggy here and even a short ride can be uncomfortable. My Bro Reaper wants to move down there, he love the heat............
Left turn signal uses solid orange wire.
Right turn signal uses solid lightblue wire.
The diode fix is for 1800 C model bikes and
prevents the turn signals from acting like
4 way flashers.
Retro and Neo models do not need the diode fix
because they have separate left and right turn signal indicators
in their dashboard panels.
The C model has only one indicator that is shared
by both turn signals.
If you replaced your stock front turn signals with the signaL mirrors,
then you might need a set of equalizer resistors
to slow down the flasher relay.
But if you are adding the mirrors to the stock signals,
then you won't need the equalizers.
You could also use diodes if you wanted your mirrors
to act as front running marker lights.
The front running marker lights are
leftside orange with white stripe
rightside lightblue with white stripe.
